Jherico Earl
- Joined
- Nov 14, 2016
- Messages
- 8
- Reaction score
- 1
Okay so here it goes... I've owned my 1993 SHO mtx for almost 2 years now and I've tried absolutely everything to make it run correctly with no luck. Mods: magnaflow Y pipe with cats removed, 3" cat back to 2.5" duals with mustang GT mufflers (sounds great by the way) all mods done while car was still having problems while trying to make the car run right.not efficient I know hahaha. I've replaced: O2 sensors, MAF, tps, crank position sensor, cam position sensor, ignition module, all plugs, all wires, fuel pump, fuel filter, all brand new fuel injectors, ran sea foam through brake booster vacuum line, removed catalytic converters (they were fine) and nothing has made the slightest bit of difference. There is no CEL I do understand this is not the way to diagnose a problem (but really, what else could keep me occupied while I was away from home while in the military lol I guess peace of mind that nearly every sensor is new) I hope to gain some insight from any of you guys. The car has always always started, and idles fine, no strange noises whatsoever. Runs very smooth. No smoke, no real "bucking" but trying to accelerate while on the highway at higher rpm, let's say anywhere above 3300 rpm, you can feel, I could call it, "uneven power" but no misfiring whatsoever. Very very subtle "bucking" you could say. Most people probably wouldn't even be able to notice it. Maybe fuel pressure regulator or alternator could be the issue? Checked fuel pressure at the rail after pump/filter/injectors were replaced and it was all up to par. Car doesn't burn oil. I don't know if I'm missing any info but if y'all have any questions, I'll most definitely answer them. I want to get it running correctly to give my 2003 wrx a run for the money haha I know what these cars potential is, and mine doesn't have it at the moment.
