Loose Steering Wheel.
Grifter
New Jersey
I know this has been covered before, but I have done a search and still havent found much useful info. It's also hard to ask questions on a thread you didnt start.
Anyway:
I have about an inch to an inch and a half of play in my wheel. At first I thought it may have been my driver side front steering knuckle. It needs to be replaced because it does not tightly pinch the ball joint. But I dont think that is the problem anymore. Today, by accident, I locked the steering wheel, and sure enough there was still a lot play in it. I think it has to do with the joints or something in the wheel itself. I checked all those pinch bolts that are known to be loose, one under the boot, and the 2 up towards the wheel, and they're all tight. I also thought it may be the rack or pinion, hopefully not, but could it be that even if the wheel was locked? What can it be?!
Thanks for any replies.
Petersho1
IL
I had the same problem, Don't remember the name of thread just check by name petersho1, I needed just some shims to fix this .
Petersho1
IL
Steering shaft, there is two parts shaft. The smaller one goes into bigger one and there I had free play. I hope it will help.
Grifter
New Jersey
I searched for your thread and found it, I actually responded to it, but I didnt get any info out of it.
What exactly did you shim?
Grifter
New Jersey
Could it possibly be the inner tie rods? My steering really scuks, I cant take it.
I still thinks it's the rack...
bmytych
