Looking for rim& tire information? Look no further!
jayro
Auburn, In
If you're trying eliminate wheel gap, get yourself some lowering springs. Taller tires could cause rubbing issues, will effectively raise your ride height, and will throw your speedo off.
x2 on the different springs to reduce wheel gap....plus you can get the added performance and reduced body roll.
kevinspann
Don't take my advice.
Richmond VA
The wheel wells on these cars are pretty big. You'd need some oddball size that wont really work to fill them.
deven.coffey
Washington
Then could you guys refer me to a thread or some site that has an easier way to get the strut assembly out of the car? When I replaced my rear struts a couple months ago it was an absolute nightmare to get them out of the wells... I really don't want to go back in there for obvious reasons...
jayro
Auburn, In
PM Sent. There are a few tricks.
Spring Hill, FL
If Mustang wheels fit the old SHO you'd see a lot more with nicer looking wheels. SHO is 108mm x 5 and the older Mustangs are, I believe, 114.5mm x 5. It's enough to constitute an adapter.
cowboy0ne
virginia
Thanks for the good info. I work at a used parts yard a.k.a. Junk yard and I can get any rims prety cheap. Will tbird or any other car fit ??:salute:????????:salute:
platoribs
Live to Drive
Plat0ribs House of SHO,il
Yes the Thunderbird's have the same 108x5 (4.25x5) pattern. SC's and 96+ sport LX have 16", all others are 15". Some brakes require 16"+ to fit over.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
You can fit 15s on a gen 3? Ive wanted to put the gen 1 basket weves on my 98.
No.
they will fit the rear with stock brakes (maybe even larger rear brakes)
they will not fit over the front 11.5" stock brakes. (with huge spacers maybe)
if you really, REALLY want the basket weaves, downgrade the front brakes to 11.0" then the weaves will fit. That's not exactly what I would recommend, but if you're after a specific look it's easily doable with bolt-on parts.
Perry
groove83
PimpTempoOwner
Kalamazoo, MI
has anyone tried the steel 16 inch rims from the focus yet? a buddy that was a ford tech gave me one and I like how it works.
kevinspann
Richmond VA
I think they have a really high offset, like +55. Probably will hit the strut without spacers...and no tires.
terrystyerjr
I have gen 1 1991 I need to know how big of a 16 tire I can get on rf with out hittinh strut its on a racecar
zak
east of Hartford
With a 16x8 wheel and 40 mm offset a 245-50-16 Nitto NT-01 just barely fit (would tag the strut under sudden direction change) would recommend a little more offset. I would not put that wide of a tire on a 7 inch or even 7.5 inch wide wheel for what you are doing. Need to run low mileage or NOS OEM wheel bearing in that position.
On a 91 the space is much more limited on the rear, 225 may be max. Also 40 mm offset is too tight I had to run eigth inch wheel spacers to clear the strut, that was with 245-45-16s.
shomethe$$$
Washington D.C.
Just remember more spacers and offset will increase your scrub radius which ruins handling. Same with lower profile tires or less overall tire height.
lingyuair
