Locked Out!!!!!!!!
Corby
Porsche Eater
Okay im an idiot and somehow locked myself out of the car... I accidentaly cut all of the power locks/wires trying to get my seat belt and door alarms to shut up.... I can however open the trunk but that is about it, is there anyway to get into the car from the trunk??????? Any input or ideas on how to get in would be greatly appreciated
jon93
Philadelphia Region
I think that if you take you vin # to a ford dealer, they can look up your key code and make you a key. If not, just get a wire hanger and try to jimmy the door open.
YAHTEC
Hermitage, PA
use a coat hanger and try to stick it through the door jam (if possible) and try to touch the unlock button good luck and I'm sure somebody else will have a better idea
AREA 91
PA SHO SHOP
Area 91
I have read on here that you can use a long and skinny flathead screw driver, and open the rear door through the handle. Do a search, and you'll get a better description.:thumb:
Lift the rear door handle and there is a slot. Inset a small screwdriver and fiddle around. The door will unlock easily.
RStalveyARFF
too many shos
Georgetown, MA
You won't be able to get through the trunk, especialy if you cut your power lock wires. I'd suggest calling AAA if you have it, they can pull the interior door handle. If not, call a locksmith.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
getting in the trunk isnt gonna happen unless you dont mind destroying you back seat. on my old GL i used a coat hanger and about 45 mins of practice until i got it.
the trick is bend it in a u shape and try grabbing something near the lock (something you can figure out on your own)
the way the seats bolt in if your wondering (backseat) is 2 bolts in the bottom corners of the back rest part and 3 hooks that sit in the top.
like i said your gonna have to mess something up pretty bad to get in threw there .
mlatten
Mons-taurus
Suffolk, NY
A good locksmith can pick the door lock in a few minutes.
My grandmother had it done for $50.
Matt
If this is a GEN 2 and you stick a screw driver in that front slot of the rear door handle you will wonder why you even bother to lock the car at all it's so easy to pop the lock.
JoesSHO
Reality
Next time just unhook the wire going to the ignition switch under the wheel trim cover- it'll stop the incessant "bonging" when the door, etc, is opn and the key is in... Not sure about the belts, though?
ManicMike
Speed Freak
Bear, DE
You mean between the 2 doors?
PLEASE explain more, i'm quite intrested..
-Mike
No, lift the rear door handle and the two slots that the hinges go through the door.
I think it's the front slot, stick a small 6" screwdriver in there and push up, you will catch the rod and push up the lock.
Usually in less than 5 seconds.....
ManicMike
Speed Freak
Bear, DE
Will it work on any other door? Does it have to be the right or left rear?
-Mike
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Ok I'm attempting this right now, as I locked myself out of the car. When I stick the screwdriver in, I feel a cable. If I push down, I can see the lock coming down. When I push up, it does nothing. Am I missing something?
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Ok this is a no go. Also, I meant that when I push the cable up, the lock kinda comes down abit. Push down on the cable, and it does nothing. I tried pushing the cable forward, etc. Locksmiths around the area seem to want to charge $100 bucks to open it. Any other suggestions would be much appreciated!!!
1993MTXSHO
Its a Taurus...
Jersey
umm, when i locked my ******* out of my F150 I called the cops and they came and popped it for free:thumb: O and btw it was at my friends house not even on the side of the road and they had no problem doing it. Cop called me dumb though:rofl: It was local city cosp not state fyi.
