lifter knock
matty
Southern Cali
hello everyone whats going on not to much here.i just got my timing belt installed about 2 weeks ago and now im getting this lifter noise its like saying crack over and over again faster than norm.do you think that he needs to re time it or is it to late? please help matty
K-Dawg
Treasure Coast, FL
The SHO motor doesn't have lifters.
The knock you are hearing might be bad rod bearings. It fools everybody.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Could be rod bearing or the cam chain tensioner went out as well. If you want a I could check it out for you.
matty
Southern Cali
thanks guys for the info loudsho ill let you know about it.i went ahead and got the rod bearings.i got the clevites standard so ill be letting you know ill take care of you if you come down.i have a couple of lifts so it should be easier matt
