Spootcat
- Joined
- May 7, 2017
- Messages
- 44
- Reaction score
- 53
Greetings All,
2016 stock non-PP, 50K miles
I had a sudden onset rattle, sounds like nuts in a can - front driver wheel area. Wasn't there when I drove to work, was there when I drove home. Pulled the tire, looked at all of the bits, everything looked OK. Took it to Ford and was relieved of $135 for them to tell me that it was my brake pad clips. OK... Always willing to learn something new. Put PowerStop and new pads on about 5K ago, they've been great, but maybe I missed something.
I put new clips in, replaced the bolt boots and re-lubed the pins (all parts were still in good working order since recently installed). Everything moves well. The pads have off side springs that are tight against the caliper holder. Put it all back together and still have the rattle. It's mostly noticeable below 20MPH - may be there over that speed and road noise hides it. Can also hear it when breaking, so makes the pad clip suggestion further suspect. The only thing I am not sure of is the small circular rubber grommet/tube that comes with the brake pad parts. I've seen a post where it is mentioned, but I can't find it again (always the way), so I'm not sure where those pieces go.
My first thought was wheel bearing, but I don't have the vibration or hum that I have had in the past with bearing failure/degradation. It's also a frequent noise, but not continuous, and sometimes it's an obvious rattle, sometimes a less obvious rattle. Sometimes not there at all. It seems very much a front/driver wheel area noise, but I guess I'll take the back wheel off tomorrow and see.
I think the dealer saw non-OEM parts and stopped looking for the problem. The fact that they said it was clips, and their solution was to replace the pads, not the clips, tells me this dealer is not industry leading technicians/customer service oriented. ****, I would have replaced the clips as a good will (and value for the $135 diagnosis fee) gesture.
Anyway, any ideas? Is there a good way to test the wheel bearing? Where does that little rubber dealy in the pad kit go?
Appreciate your time and insight!
Spoot
Spoot
