supersport
all other windows go down, i took the door panel off and checked it out, made sure switches were all good, i am just puzzled still.
While you have the panel off, check with either a test light or Digital VOM (volt/ohm meter) for power at the motor while pressing the switch to the down position. IIRC the switch reverses polarity for the up function of the motor. This test will determine whether the motor is faulty or the problem lies in another component or wire. Good luckall other windows go down, i took the door panel off and checked it out, made sure switches were all good, i am just puzzled still.
