large SHO fuel injector/fuel system
yamahaSHO
E85 whore
Arkansas
First I've heard of E85 intakes being cleaner due to the running of E85. You're over-stressing about this.
somedude_001
Western NY
yamahaSHO do you think the ID1000 are enough or should I step it up to the id2000? Or is there another injector on the market I should be looking at?
yamahaSHO
E85 whore
Arkansas
ID1000's should be plenty big enough. If the system backing it is good, bump the pressure and these things perform VERY well.
somedude_001
Western NY
I just want to verify again before I order these. but Order them for a mustang 4.6 quantity 6 and pop the caps off and they will fit the SHO with a stock fuel rail?
yamahaSHO
E85 whore
Arkansas
You ever figure out what ID1000 injector fits? I may be in the market as my 48 lbs/hr injectors aren't big enough after 7,000 RPM currently and I'm looking to add more power.
yamahaSHO
E85 whore
Arkansas
I am still trying to make sure this is 100% correct fitment for my setup (bored rails), but here is what I got back from Tony Palo for ID1000 fitment.
"Perfect, what you need is 60mm length, 11mm top oring, and denso lower cushion. All in stock. 1000.60.14.D is the part number. $120/each"
Further clarification:
- If you want them to fit the modified rails, the part number will be 1000.60.14.D
- Mistake below, for OEM rails is 1000.60.11.D
yamahaSHO
E85 whore
Arkansas
Looks like I will be giving these a try in a week or so. I'll report back once I get them. If these fit, there really is no better injector to get when going this big (95 lbs/hr).
