Keyless entry module for gen 1
SHOrod
Torrie Tuned
Cedar Rapids, IA
Do you mind sharing your symptoms and what has lead you to think the module is the issue? We might be able to help further troubleshoot. I haven't really heard of many issues with the RKE modules.
For example, do either the FOBs or the keypad on the door work? Do the door keypad keys light up when you press one? Does the power door lock switch on the master window switch work?
-Rod
Devin
3.Slow
Pacific Northwest
Door keys do not light, it is all dead. My door lock doesn't work right now but was working before I futzed with it...
SHOrod
Torrie Tuned
Cedar Rapids, IA
I'd suggest checking powers and grounds first, if you haven't already. From the Fuse Panel - Circuit Breaker 14 (20A, hot at all times), Fuse 8 (15A, hot at all times) and Fuse 5 (15A, hot in Run). Or at the Keyless Entry Module - Pins 13 and 14 of C2, pin 2 of C2, and pin 8 of C1 respectively with the fuse panel fuses. Also check grounds at the Keyless Entry Module - Pin 2 of C1 and pins 5 and 6 of C2.
-Rod
SV&HOdan
Pittsburgh PA USA
Devin,
I think I what you're looking for: part number E9DB-14B001-AB; door code "23902". $36 shipped.
thanks,
dan
