K&N Cone filter probs?
cellar
West Bloomfield, MI
hey guys, i'm new to this forum and I just bought a 96' black sho about ohhh 3 1/2 weeks ago and i'm lovin' it. I'm just about to get my car checked at a dealer for basicly everything just to know what needs to be replaced and what not (I normaly wouldn't bother but i'm not the one payin' the service bill). and yes it has been welded
I was just wondering if anyone here had been having problems with the K&N cone filter as far as hot weather/heat would go. I go to school down in Indiana and a lot of my buddies have these on their cars and say that if there is a hot stretch of weather that this thing actually hurts their performance? I just thought i'd toss this up to all the people here that know infinately more about the sho then I do at this point. Thanks for any help
stephen newberg
Ladysmith, BC, Canada
I agree. The cone under the hood causes engine performance to suffer in warmer weather. Some form or porterization, that is taking air directly from the gap between the inner and outer wheel well, is the way to go.
pax, smn
DavidT
TN
Glue Maker said:
Yep. Go for porterized.
I have had both, and porterized works better in hot weather.
Did you ever test this theory at the track?
Glue Maker
The V8 Paradox
Sugar Land, TX
I let my brother have my K&N cone, so I can't test them one after the other. I have compared in a sort of bench racing fashion, and the porterization set up helps a lot when the sun is up.
Findings:
60'- Same
330'- ~1.3 tenths saved
1/8- ~1.7 tenths saved
SHOBOI20
canada
can i put the K&N cone right on the MAF on my 1990 SHO. i dont know how do go about this. i am dieing to put a cone in but i dont know where to start?i know i can make a tube, thats no problem. i can do many mods to make the cone fit, but does the cone just fit on the maf. anyone know the cone product number so i can order it.
SHOBOI20
canada
hey guys how do i remove the the snorkel on the ouside of the fender where the air box sucks in air? can i remove it, cause it looks to me like i have to take off the side panel....i took the bolts out so its loose but then i cant get it out, it stuck. anyone?
americanmotorsport.com said:
If you guys do use K&N's and such, I recommend NOT re-oling, andjust getting a new one when timecomes. Read ths:
http://www.americanmotorsport.com/faq.htm#q7
After using a K&N type filter for 5 years I have not had a problem. I clean it every two years and have not had any MAF problems. The MAF is very easy to clean anyway.
Why do the oiled filters not cause problems when new? I feel the real problem is people use too much oil and clean the filter too often.
Wess
Jarhead
MD
I agree, that's why they color the oil red, so you know where you've oiled. If you're worried, clean the MAF a week or so after you've re-oiled.
Ian Macoomb
Ottawa, Ontario, Canada
I've done lots of testing at the track. Trust me the SHO loves cold air. Mine will run low 15's in sub 45 degree weather and 15.4-15.7 in anything warmer than 65 degrees.
the_dude
Ottawa, Ontario
Does anyone have an opinion about whether or not a cowl hood would let enough cool air in to use a cone filter without losing too much performance?
Ian Macoomb
I don't think a cowl hood is what you want. You'd have to have the filter located close to the cowl to get the benefit (my speculation only).
What I'd like to do is make a fiberglass hood with a subtle scoop like they put on some of the Subaru's. Nothing too big or ricey, but something that could look like it came that way stock.
