LJRuddy
Pop lock n drop
And I R has sum kwestions!
First off, I have decided to go with the Cobra calipers on the Gen 3 11.6 inch rotors. With that said, I started to read the how to for this option as well as every reply below it.
In the how to section, it says to use the banjo bolts from the stock caliper. So that means my banjo bolt from my 95 SHO caliper will work with the Cobra/Mach1 caliper?
What exactly is a Z sized drill bit?
I don't feel safe driving a car with weakened knuckles so I am choosing to have the bracket notched so that it will fit flush with the knuckle. However, later in the thread (pg 2 i think) someone said that after you redrill the mounting holes .7" up from the stock holes, you can then chop off the bottom where the old holes were instead of just grinding 1/4" off. Is this true? How much will I need to have the machine shop cut off?
I also read the part where Zak (i think) was calculating the sweep area of the Cobra pads versus the stock gen 3 pads noting that the gen 3 pads have a 5% larger area per rotation than the Cobra pads do. However, someone countered that the Cobra caliper is better at heat management and thus makes up for the smaller sweep area and then some. Is this true? Someone said that a 11.6 with the Cobra caliper is no better than your plain jane gen 3 upgrade. Is this true?
I am sure I am forgetting some questions so I will update this later as they come back to me. However, feel free to post any other necessary info. Those of you who have done this swap are encouraged to post with your findings and problems you encountered during the swap. :wave:
EDIT: Is anyone having problems with the stock taurus master cylinder when it comes to the larger caliper displacement?
Also, will the Earls SS Brake Lines be compatible with this brake swap? I just dropped some money on a set and if they wont work with the cobra/11.6, i will just stick to the gen 3 swap.
