Just bought new car, misfire help
mattfoo83
SHO NUFF!!!
wildwood, florida
just got a 91 mtx. had a very bad misfire on the drive home 0-60 in 3 miles! got home, at night, noticed spark under the rear of the intake, removed upper intake, found 2 plug wires not fully on spark plugs. the first one pushed down great and mated with the valve cover. the sec left a small gap between the cover and wire boot. this plug with also was discolored like water or steam had been in there for some time. i havent quite gotten the hang of the test where it checks each cylinder. now it seems to be down only 1 cylinder. starting it with the #2 wire off doesnt seem to change much.
should i just replace the wires and plugs and go about my busness or should i be worried about this further.
its a 91 mtx with 135k on the clock, im a ase certified mechanic by trade but want hints on what the SHO gods think. im always up for learning:hail:
bubba
ATX Connoisseur
Fort Wayne, Indiana
pull your codes to helps to find out what it is. it could be the coil or DIS causing this too.
itwonder
VA
Blow out the plug wells and see if there is any water or oil down in there. Oil indicates time for new valve cover gaskets. I'd go ahead and put a new set of wires on and replace at least that one plug.
mattfoo83
SHO NUFF!!!
wildwood, florida
ummmm whats water mean? not alot butr 2 plugs where blacked out (not firing) and had some rusty water in there.
whats a normal compression check (psi) read?
mattfoo83
SHO NUFF!!!
wildwood, florida
ok figured that out...... now im down only on #5. im doing plug wires in the morning will update on that. hopefully that pics #5 back up
