Just bought a SHO, now what?
Daedalus
Gen3 noob
Simi Valley, CA
Congrats on your purchase, sounds like you got a good price. I paid the same amount for my '99 with 135k, and your '98 has a lot more goodies.
I agree with everything that has been said so far regarding the cam welding. I had mine done 2 weeks after I bought the car, and the guy who did it said that one of my sprockets was starting to work loose. As others have stated, there are very good resources available on www.v8sho.com, hopefully there is someone near you who is listed in the cam welder directory.
But after that, I am going to have to disagree with those who recommend performance upgrades. With 100k miles, your car is probably going to have many of the issues that mine has, and to me the number 1 priority is replacing worn parts to get performance and handling back as close to stock as I can get it. That means new ball joints, tie rod ends, struts (my non-SARC struts are more prone to failure than the SARCs as I understand it), coil springs, A/C compressor clutch shim, etc. Only after I have everything working as I want it will I consider upgrading it.
And in that vein, although the V8 SHO is a very fun car to drive, and manages to put a big smile on my face on a regular basis, in all honesty it isn't a really fast car, and short of something extreme like nitrous, there isn't a whole lot you can do to improve acceleration. Personally I'm planning on sticking with a Troxelized intake, 26mm rear swaybar, and maybe some new mufflers.
So anyway here is my plan which I am following on my SHO:
- Weld cams
- Basic tune-up, new belts, plugs, coils (done at the same time as the cam weld)
- Change all fluids and filters, flush transmission, bleed brakes
- Thoroughly inspect car, and make a list of what is worn / broken
- Fix all stuff on list
- Consider performance parts, especially if it's a part you are replacing anyway as part of the previous step.
Vnuk1
Mr. Mayhem
Minnesota
Hello and welcome from the MN Section! You have come to a great community of SHO owners and a Forum with a wealth of knowledge. If you have any questions there are many people here on the Forum as well as in MN that are more than willing to lend a hand. Alot of great info listed above so I wont need to add anything.
SHO1
Coke Is It!
The State Of Hockey
Welcome from the MN group and check the MN section, we do have a meet now and then and you're welcome to join anytime.
Atleast one of us does have some experience w/gen 3 SHO's. No cam failure personally, but the cam issue is the 1st thing that needs to be taken care of if it hasn't been already.
three50one
Gettysburg, Pa
I was assuming all maintenance would have been done before asking about improvement.
I think the cheapest and one of the most effective things to do is aluminum subframe bushings.
Since Eibachs are no longer made I don't really know what else to really stiffen it up other then swaybars. You can still get the Konis but you would have to go with normal springs.
These cars handle very well and that was one of its selling points to me. They may not be rocket fast but they like to be thrown around.
I have the Gen 2 Konis in the Gen 3 strut housings with Gen 3 Eibachs. Work pretty good.
stephen newberg
Ladysmith, BC, Canada
I certainly agree as per the bushings, but the other thing to do is the front strut brace. Think of the frame as a box with its corners as the tops and bottoms of the struts/shocks. From the factory you have anti sway bars at the bottom of the box already, and there is also a bar that ties the tops of the back shocks. Only missing is the stiffener for the front top of the box. This is what a front strut tower brace does. It makes a significant difference, as do the subframe bushings.
pax, smn
As does the short subframe connectors. It is immediately noticable. Also gives good jack points.
three50one
Gettysburg, Pa
You would have to make the brace custom no? Though I agree completely with you my train of thought was things readily available to buy and things I had experience with. Both of those I have none with.
Use the regular shorty braces but you have to box in the forward strut tension rod bushing area. Good Idea to change them first......
stephen newberg
There were pre-made front strut tower braces available. I bought one half a dozen years ago or more, but I do not think he is in business any more. Might try NESsho or FPS. Anyone know if there are any pre-made still around?
pax, smn
Izzmo
SHO Enthusiast
Kansas City, KS
How is that suppose to help handling? It doesn't look like much (or connects to anything in particular)
Bill Strobel
theamcguy
Fayetteville NC USA
Hey everyone, I just picked up a '98 SHO with 103k for $2000. I used to be into little import cars, and had a '95 Eclipse but I decided it was too cutesy and I wanted something a little more badass but less flashy. I met this guy once who had a SHO and decided I wanted one.
I finally traded up for it but I don't know what to do now to improve upon it. Where do I start?
Buy lots of tools and a shop manual
