Just a quick question about mods! Thanks :)
GA
Would I be able to install the supporting mods for the GH tune (MAP sens, Therm and plugs) without having the tune yet?
Just wondering. Thanks
76FoMoCo
Nampa, ID
A bit smoother idle. Now after the tune is a totally different animal.
Ecoboost_xsport
Sacramento, CA
These are the correct plugs?
The M-12405-35T plugs are the SP542. They SP542 was removed from Ford's standard lineup and moved to their performance lineup and given a new name. There was an emissions compliance issue that doesn't allow Ford to use them as OEM in "average cars". The Ford GT uses them, but I think it is allowed under different regulations or something.
At least this is what I read a few years ago. Not sure how accurate it is.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
that is correct. [Cue Chris Farley taking his shirt off]
RickyRecon
Northwest Indiana
The plugs will be fine, but not the MAP. I also believe you need to have the tune adjust the fan settings for the Tstat. I personally skipped the Tstat because after some deliberation I decided to just let it run at the temp Ford thought was good. These ecoboost motors are dirty.
On that note, if GH is out of the tstats again, and you want a 170 still in the box from them, let me know haha
GA
Thanks for the info man!
76FoMoCo
Nampa, ID
You can always go down on temperature with the t-stat you just can't go the other way because of the fan setting. Your tuner will change those when he tunes it for the stat.
DouglasB_SHO
Former owner 2011 SHO
Sagamore Beach, MA
Thanks for sharing this good info. I'm doing the GH tune and MAF on my 105K 2011 SHO. I already have the CAI and SP-542 plugs and currently an SCT tune. T-stat is stock until I have decide it's time for some engine internal maintenance. I like what has been shared in the forums about the improved shifting from the GH tune.
Ecoboost_xsport
Sacramento, CA
FYI, it's MAP, not MAF...two different things.
