Jordan_R
I've heard from a couple different spots that the thermostat is 160 degrees. I'm deleting it personally. Might add one in line down the roadYup, I was doing some research on this very thing as I will be adding one myself:
Question I can't find the definitive answer to is...what temp is the factory thermostatic valve set at (item #4) I can't seem to find the answer...I'm going to replace it with an aftermarket one, but want to compare temp settings as you can get aftermarket ones at various temps.
Anybody know or can find out? That part number I wrote down is the PN for the valve
