jacking positions
poissonverte
iowa city, ia
Anyone have a good place to jack the car up front and rear spots?? the spot i used kinda collapsed on me.. nothing major or bad it was the little rail that i thought you were supposed to jack up.. oh well.. no harm done.. but I just watned to know where youre supposed to raise the car.. pictures or detailed descriptions would be appreciated.. thanks..
SilverSHO
cartersville
For raising the front, I usually put the jack in the middle of the front subframe crossmember, and put the jackstands on the side beams, back by the tires, to keep them out of the way. For the back, I use the control-arm box. Probably not the best place to do it, but the only place I could find.
Shoman594
Moderator
Lockport, IL
Had the same thing happen to me once eek!
right in the cornner of the wheel well and the front door if you look at that rail there will be a 2 inch part that looks like it is reinforced, thats where you will put the jackstand. you can use the rail behind to temp jack up the car.
poissonverte
iowa city, ia
Maybe i should have titled the post.. "on what location do you place the jack/jackstands to properly raise your vehicle safely and effectively off the ground, so you may crawl underneath it" :p
SilverSHO
cartersville
fredhurderjr:
"jacking positions"
Hmmm... I'm not going there.
Yeah, yeah, go on with your bad self.
[melodramatic music in background]
Corrupting the minds of young forum-goers. Is this what we've come to expect from our moderators...our LEADERS...the ones who are supposed to ensure that the forum is a place of growth, of friendship, and of occasional post-*******???
[/melodrama]
:cool: burn_out
jthomas68
Area 51
The front i also use the center front of the sub frame.The rear i use a block of wood on the jack,and raise it by the H-brace.When i did teh aluminum sfb`s,i had to put the stands just behind the suf frame on the rails.The whole car flexed a few inches!!I guess i need sfc`s thumbs_u
