jack points
walt
pittsburgh
i have to jack the back end up to replace my sway bar links because i snapped one, but i cant figure out were to jack it up at. i can jack it up but then i dont know were to put the jackstands.
raze
Connecticut
I did this yesterday. I took a jack, and a small piece of wood(2x4), and placed it right in the middle of the rear end of the car, where the control arms connect. make sure you put it on the flat part, and not the thin metal. When you start to lift it up, check to make sure everything is secure, and that the control arms clear whatever you used inbetween the jack and car. You might want to get two end links just to make sure its nice and equal. when I put them in, I also had to use another jack to push the swaybar up so I could bolt down the end links, its pretty straigh foward, and helps if another person is there to help, good luck :)
