94' ATX 178K miles.
All parts ordered from SHOsource so I didn't cheap out on anything.
CPS
Camshaft Position Sensor
Timing Belt
Water pump
Vacuum lines
Front Seals
Plugs and wires
Valve Cover gaskets and plug well seals
Timing tensioner and 2 brand new timing pulleys
She starts nice and quick but once idle goes down it stumbles between 900-500 rpm. It usually jumps between 900-700 though. It will even run perfectly fine for 10-20 sec and it starts to stumble again. Engine does not shake. When driving you can feel lot of hesitation when applying moderate/steady gas.
Car does not feel like lost any power. When you floor it, she jumps nicely and pulls hard. Secondaries open up too ofcourse.
I checked vacuum lines and no leak as far as I see, I've reassembled timing belt 3 times, I have gaped plugs and re checked firing order. All good. Everything is connected as far as wires go. Ground is good too.
What could it be?
DIS module? COIL?
I'm ready to set the car on fire ad run it off of a cliff.
CPS
Timing Belt
Water pump
Vacuum lines
Front Seals
Plugs and wires
What could it be?
DIS module? COIL?
