sortafamous
sometimes when i use the eatc, i hear these kidn of clicking noises for few seconds when the fan seems to be coming on..
is this the blend door?
Shoaz said:The BDA failure makes more of a thump than a click, so I'd make sure that this is what's failing before you go tearing into the dash.
There is an EATC self-test that can be done to verify that this is the problem. A search here or on shotimes should turn up the test procedure.
That will normally hint you to what is going on...
