Is this a problem
strykr14
Michigan
I was replacing my halfshafts when I noticed this. It's on the Passenger side halfshaft - the plastic peice that sites up against the seal. Is this a problem?
1993MTXSHO
Its a Taurus...
Jersey
I wouldn't think so, but get some other opinions as well.
and there we have contradicting posts haha
AREA 91
PA SHO SHOP
Area 91
Not really. I've seen it before. It just helps keep more crap from getting in the tranny.
strykr14
Michigan
What's a halfshaft?
I dunno, it's the part that goes into the trans on the passenger side. Personally, I don't think it's an issue - its not a seal, I think it just stops the halfshaft (axle?) from going too far into the trans. I may be wrong though, that's why I'm asking.
AREA 91
PA SHO SHOP
Area 91
Technically that part is the intermediate or carrier shaft. The most important part is to make sure the bearing is good and the two mounting bolts are tight.;)
TYSHO
Earth
No problem, I've been running one of my SHO's like that for years. The output shaft seal, installed on the transmission casing, is what keeps the fluid from leaking out the transmission shaft opening.
I've found my piece hanging in the middle of the shaft, having to push it back into place to protect the seal from any outside debris that can potentially damage the seal.
Any pictures of the SHO wearing the green slicers? :)
TYSHO
Earth
You have to bolt down the carrier bearing and that holds the shaft in one position only, making it impossible to install the shaft further than it should be. You're good.
Edit: LOL...I should've read more down, AREA 91 just covered this. I'm leaving this here for the more in depth explanation though.
strykr14
Michigan
What's a halfshaft?
Thanks for the info, I'll go ahead and install it tomorrow.
strykr14
Michigan
Dude, You got nice SHOwagon!! Props to you!
Looks great but I am having to replace the whole front and rear suspension, including subframe. Because I am doing that I'm also upgrading alot of crap and taking care of stuff that needs taking care of. Alot of work. Oh, and it needs paint. can't tell from the pic but there is alot of hail damage.
bmytych
