Is there codes for bad fuel pump or plug cats?
Pete89sho
Belle Vernon PA USA
Will a code show up if my fuel pump is bad of if my cats are plugged up? I am planning on buying a code reader today, but would like to know if it will diagnois this problem before I buy the code reader. Thanks
You don't have to buy a code reader to view the codes. The EEC will blink them out at you with the CHECK ENGINE light if you jumper the test connection under the hood. Once again....
General procedure: http://www.shotimes.com/SHO3eeccodes.html
Detailed procedure: http://www.shotimes.com/references/eecarticle.TXT
'89-'91 2 Digit Codes: http://www.shotimes.com/SHO3eeccodes2.html
'92-'95 3 Digit Codes: http://www.shotimes.com/SHO3eeccodes3.html
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
SilverSHO
cartersville
If you really want to use a code reader, Wal-Mart has one for about $25 that comes with a manual that explains the codes and how to use the code reader itself. Of course, the GM reader they have is cheaper
Nick
Lt. Titanium 90 135k
Coneless, ACCEL 8.8 stainless steel wires,
SHO Shop torque limiters, Cherry Bomb Turbo II mufflers (sound pretty damn good for $15 mufflers :D )
New to the family: '73 VW Beetle...MUCH less expensive to mod than the SHO, but somehow not quite as much fun ;)
AIM: loudog6491
