is the 3.2&3.0 intake/& valve covers the same?
187 SHO
west babylon,ny
i want to part out my 94atx 3.2,but i would like to polish the intake&valve covers to put on my 95 mtx.is this possible?
Are the valve covers the same? Yes. Intakes? Read below.
Ishodu
The ATX intake will have the EGR setup on it. Most MTX will have the castings there but not in use. You would just need to cap off the EGR ****** and it will work IIRC.
Ishodu
Valve covers are the same.
I hope you know what your getting into, polishing takes a lot of work and time!!
well, he does have the rest of the winter in NY.....
Doh! I was thinking only of the valve covers. Thanks for correcting the info about the 3.2L intake and its EGR port to ingest the nasty exhaust gases into the intake.
Westerly, RI
FYI, some of the older Vulcans that didn't come equipped with EGR had a cast aluminum blocker plate that should fit. And being aluminum, it can be polished and are belong to Tom.
