Is stock FPR ok with Walbro 155 lph pump?
roswell998
Atlanta, Georgia
I've searched and read a number of posts made over the past couple of years, but I am interested in the most up to date concensus:
Does the stock FRP work correctly with the higher than stock capacity Walbro 155 lph fuel pump or will a different FPR work better? If so, what regulator is recommended?
Thanks
Ishodu
That pump will work fine with the Stock FPR. If you feel you need an aftermarket one the SHONUT high flow unit is the way to go.
