Is my torque converter failing?
dlanes
MN
Lockup is sluggish sometimes especially with 2-3 shift. What is the stock stall because mine is about 2500rpms which seems a little high.
LJRuddy
Pop lock n drop
Poaceae fields
When you say sluggish on lock up, how slow is it being? My converter seems to lock up rather "weakly" at rpms below 2500. When I say weak I mean it tries to lock up in 3rd or 4th but if there's more than about 10% throttle input, it seems to get halfway locked up and just chill there until I reduce the load. If it is doing this, I wouldnt worry about it as mine has done that since day one and I think its part of the programming from Ferd.
dlanes
MN
Well most of the time it's ok other times it downshifts with like 10% throttle and it hangs there for a bit. Wide open throttle on 2nd to 3rd shifts it will hang at about 4500rpms before locking into 3rd at around 4000rpms. Once in a great while it also studders when slightly giving gas I'm guessing because it's trying to upshift then down shifting.
dlanes
MN
So why is mine 2500rpms? Is my tranny going to give out on me. No one has experience with this?
Mr Anonymous
Tire Wall
You have the wrong converter in the car, i.e. a V6SHO converter. Happens all the time. I believe in either the post I linked or that thread I mention the problem.
dlanes
MN
Does that mean I need to swap it out? Where would I find a v8 torque converter?
