Intrerior door handel is loose.
T.O_SHO
Power Hungry
Toronto, Ontario
Yeah, so my interior driver side door handel is a little loose...It feels flimsy...not like its going to break but it feels loose. Its got alot of leeway. up down and right...Im sure something needs to be tightened somewhere, but where excactly is what im asking... It will still open the door but you just have to pull a little farther then usual, no big deal I guess but Id like to fix it...
Thanks
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
I believe what you are describing would be the typical inside door handle problem. The spring that holds the handle broke/fell off.
I noticed that happened on my 94.
RAYJAY
WHO ME ?
UNION DALE PA
i got one at the jy the other day was just going to fix the original one for xtra parts on the shelf :) ty any way
can't have enuf sho parts around the house ............
Jeff
T.O_SHO
Power Hungry
Toronto, Ontario
Whats involved in replacing the door handle? Im assuming you have to take off the door panel, but is it easy to do? Furthermore, how hard is it to raplce the spring,,,Thanks alot for the help...
