Intermittent stalling
Vince7
Rhode Island
Hello, its been awhile and the sho has been great, and finally warm in the east, i had a previous stalling issue before and found some corroded ground contacts so i replaced them and it has never stalled again that was 4 months ago, and besides an oil change things have been good, i'm driving about 40ish
and blink it just quits so i hit the key it restarted for about 100feet, and quit and wouldn't restart, the TACH is reading about 500 when i crank it and i hear the fuel pump, so i decided to grab a coffee and five min later it started, damn what a bugger, for a note i have never changed the wp/crank sensor/ cam sensor or timing belt , i'm a bit confused usually when it dies and is the crank sensor , so the search i did on the forum told me that the tach usually doesn't read, oh by the way the engine doesn't pop or do anything weird it just cuts out, and the only thing minor i did was change gas type's due to the cost in the past months i have been using regular and 2 days ago i put some premium in , i don't know if thats a problem, well i'm off to check the codes, and i'll have a look to see if anything noticable is wrong, i haven't been loosing coolant either.....any help would be helpfull :D
dudev
Idaho Falls
My $.02
Look at the battery connections. A smaller wire that branches off of the the neg terminal is very important for the computer to operate correctly. Also if you are stalling at low RPM it could be the IAB. I've seen a lot of stalling problems solved by replacing the IAB.
crystizel
