Interior lights
guitar
MN
Ok, so just yesterday when i was driving my interior lights just randomly started turning on and then off. I will just be driving then all of a sudden the lights will just turn on for a second then shut off. I didnt do anything different yesterday that would have randomly caused this to do it so im just completely lost.
hawkeye18
Sorta cares
Norfolk, VA
sounds like a door switch is starting to go bad...? try seeing if any of them are loose/wonky... if you know what I mean.
guitar
MN
I looked at the door switches and none of them seemed loose and everytime i pushed them in they shut off the lights like they should but idk if theres one going bad still even though they all seemed to work fine or if its something else
guitar
MN
anyone? i drove for the first time at night and its really annoying
RiceeatingSHO
Travis R
Alabama
Is your dimmer **** right on the egde of turning them on and it is just bouncing on and off...maybe?
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
door pins, dimmer switch and if nothing else try the keyless entry box.. i dont htink its the keyless entry box but i guess its possible..
take all the door pins out and inspect them and also pull the connections off make sure there is no rust on them..
the casing on the door pins also tear from being slammed etc and they will look fine in the door but once you get them out you will see a rip in them and the pin can slide threw all the way and not ground it out to complete the circuit
guitar
MN
what ive found out is its only when i accelerate so im even mroe confused but my friend thought maybe something with the ignition module or something along those lines
