Interior Bulb Full Listing
DoC-JoneS
Newport News, VA
Looking to change over to an green LED interior setup on my 93 and i'm looking to find an entire bulb listing. Here's what i've got so far...
Lights in footwell x2
194/168
Map Lights x2
194/168
Overhead Lights x2
Lights at edge of door x2
Ashtray Light
68?
those are all the ones i can think of. any help would be appreciated...
DoC-JoneS
Newport News, VA
yeah i have no clue wht they are either. but hopefully i'll pop them out at work tonigth and get a size for the little buggers.
SHOnuff93
Dublin, Ca
if you want to simplify the search for bulbs for the overhead lights, just wire in a socket that takes the 194 bulbs. Thats what i did.
PuckHead
www.mn-mason.org
Princeton, MinneSHOta
TheKrazyRaven:
the overhead ones are the cylinder shaped ones w/ contact points on each end
no idea whats the size code is though
Didn't say if he had a moonroof or not so I can't be sure, since I don't have one.
The overhead (dome) one is a blade style, just bigger than a 194 but a 194 works in just about all lamp locations where a small blade style is required. AAMOF, I have a 194 under the hood right now. I re-did all my interior lights to blue LEDs.
2x Kickpanel - 194
2x Door-edge - 194
1x Dome - 194
2x Map lights (I used white LEDs) - 194
1x Ash tray (left it white as well)
1x Gear selector light on console - 194
Later!
burnout
<small>[ January 15, 2004, 02:09 AM: Message edited by: PuckHead ]</small>
DoC-JoneS
Newport News, VA
put all the bulbs in yesterday. looks friggin awesome. EXCEPT for the fact that i couldn't get the damn sunroof console down and thoes lights are still white, and totally **** the al green look. anyone know how to get that little bugger down? or am i just an idiot?
Ferendon
Fort Worth, TX
You should be able to pull back on it, and pop it off the clips. My roommate has a Gen I with Moonroof, and that's all he has to do. Only problem is, his is hanging now cause we can't get it back on the clips.
DoC-JoneS
Newport News, VA
anyone with a gen II know how to safely get the sunroof console down without breaking it. i've got two of the corners loose but i can't get the other two, it's ********.
drivinhard
Gainesville, GA
To take the console off (or change bulbs) you need to take the switch/lens covers off first. You can simply change the bulbs after this without taking the whole console out. If you want to take the console out, there are 2 screws that hold it in (remove these after taking the covers off)
To take the covers off depress the switches, and hold them in. Take a small thin flatblade screwdriver in the center, and pry that side of the covers/lenses off. Gently, they should pop right out. FWIW they take a 912 bulb, not 194 (although they'll fit) The 912's are probably a little brighter. May be a different story with LED's though....
Sho_Freak
^^ Awesome!
Iowa
anyone know what size the little light behind the headlight switch thingy is?
Zap
West Bend, Wisconsin
Out of curiosity, what type of LEDs are you guys using to replace the bulbs with, and where can you find them? I've thought about using LEDs before, but never looked into it further.
Thanks!
DoC-JoneS
Newport News, VA
well i ended up using traditional bulbs colored green (we had them 30% off @ autozone). the LED's i was planning on using can be had at www.superbrightleds.com if anyone is interested.
EDIT: thanx to drivin hard my SHO now looks like an apache at night!
<small>[ February 13, 2004, 05:35 PM: Message edited by: DoC-JoneS ]</small>
SHOMA
Springfield, MA
Not trying to jump in on your post, but if you buy a different colored #37 bulb, that still wont change the color of the backlight, right? How would I go about changing that? I have a Green 92, but put the guages in, and will be doing the 194 floor bulbs as well.
Kevin
tinkerkathleen
