Scott597
Has anyone else had this part go bad? I just had one replaced but it still seems as if the same problem occurs(Stalling when hot). I have it back at the dealer(the dealer was cheaper then most of the garages around here). Are alot of these defective or what? Also, with the car running when it gets to normal temp and the fan turns on, sometimes, when the hood is shut, the engine will surge and there will be a slight grinding noise coming from the drivers side.Any hints at what the problem might be?
