intake runners.....
Atauri_92
cincinnati, ohio
hey! How neccessary, and beneficial would it be to clean out my intake runners.....I dont think that its ever been done....anyone out there have any reccomendations on how to em` clean out, and with what???
40BelowSummer
Puerto Rico
Not necessary but beneficial. Buy a few cans of Berrymans B12 carb cleaner or euqivalent and go to town on it! For the remaining gunk in there I have had very good luck with "gasket remover" It breaks all the carbon crap up and basically wipes right off!
To do it right plan on disassembling the intake which you'll need new gaskets, roughly $40-$50 (i cant remember)
Atauri_92
cincinnati, ohio
i noticed that on the throttle body there is some kind of warning lablel about using cleaners on the intake, does it matter, or will any kind of carb cleaner be good, and what is gasket cleaner??
Sho_Freak
^^ Awesome!
Iowa
CLEAN THEM!!!!! :thumb: the gasket set at napa is about $42 and its well worth it to clean those runners and the tanks, about 4-5 cans of berryman b-12 chemtool at ur local wal-mart, and i also recommend getting some flexible 1.5" diameter engine brushes(like $4 for a set), it goes much faster, and they look cleaner when ur done! :salute:
i never really cared about the warning label on the tb, i cleaned the crap outa both of mine, and never had any trouble.
NOT JUST ANY CARB CLEANER WILL WORK! none can work like b-12, ud have to use about 2x as many cans.....gasket cleaner works, but ive never tried on my intakes.
lndshark
Jolly Mon
Coeur D Alene, Idaho
Just bought new intake gaskets from NAPA, paid 32 and change. Check them out. Thats for the complete set, intake manifold gaskets, all the runners, IAB gasket. Might want to invest in a new throttle body gasket as you will probably be taking that apart from the manifold. Think mine was two or three bucks from NAPA also.
Dont kow how long since the car has been serviced, might want to consider plugs and wires, a snap with the manifold off.
Check out the SHO Phoenix Project website for the disassembly instructions, make your self aware of the coolant lines, and vac lines. Its in the uppper 60K part, great pictures too. lost a vac line last time i took mine off, went to the website, and found the source of the vac line, went to my car and found the stupid thing.
Oh, and dont forget to cover the intake holes with shop rags or something.
n8rsk8r
Hey Where's my post?
Olathe, Kansas
I know that there is a special coating inside TB's, I don't know if it is an anit-static coating or what, but to my knowledge it is supposed to be there. And you are not supposed to clean it. So says ford, and my dad, I trust the latter of the two.
Atauri_92
cincinnati, ohio
ok.... :confused: so then what is a guy to do with his sho. And what is gasket cleaner??? is it a tool to remove the gasket, or is it spray cleaner???
40BelowSummer
Puerto Rico
guitar333 said:
Gasket Remover I meant, my bad
Wait I did say remover. Its some sort of penetrating spray that removes gaskets. All part stores will (should) have it. It will basically make the carbon soften up and wipe away smoothly. I accidentally found it out and now I use it all the time. It works great!
Atauri_92
cincinnati, ohio
ohh ok, well will i need a gasket remover?? or will they come off with a small screwdriver...on second thought i will get the remover, screwdrivers have a tendency to screw things up when they are in my hands.
n8rsk8r
Olathe, Kansas
it is a really potent cleaner, to remove gasket that has hardened. Don't clean the inside of the trottlebody unless it needs it I guess, the runners and tanks are different, the TB is a whole other area, clean the IAB valve though, It is a sinch to do, take it off, watch out for the lower bolt, and clean the spring, it gets hella carbon build up in there and doesn't work properly, gets stuck, is you TB okay? I checked the TB on my mustang, it has 187,000 and some change, and it is perfect, no crap what so ever. On a different TB, it was gunk-di-fied, it was nasty!!! Oil, caked oil, and more oil, nasty, in that case I cleaned it out, not much you could do on that note. take the advice above, but just watch the TB, I will try to see what that coating is for.
Atauri_92
cincinnati, ohio
cool, i dont think the tb is in bad shape, it looks nice and clean to me so i wont mess with it, but what is the IAB, and where is it, b/c i prolly need to check it, and what do i clean it with???
40BelowSummer
Puerto Rico
The silver lookin can thing on the driver side of the intake w/ an electrical connector going to it
n8rsk8r
Olathe, Kansas
see where the TB goes into the plenum ", it is the deal that is sideways, to the right, in this picture, of the first rubber gasket on the main tank. It is the Intake Air Bypass, so when you are at idle, this is controlling the airflow, carb cleaner is what I used, oh and an old toothbrush. and you got it!
Atauri_92
cincinnati, ohio
ok, i see what you are talking about, so how do i clean it, does it have to be removed?? or can i clean it the way that it is?
n8rsk8r
Olathe, Kansas
naw, take it off, there is a couple openings in it, just spray the cleaner, let it sit for a min on the springs to penetrate the carbon, then with tip of toothbrush "gently" clean the spring. watch out for the bottom lil bolt, it wants to fall into never-gunna-find-me-land.
SHOfun 93
Euless, Tx (Fort Worth)
Well then I guess I am screwed on my ported 69MM TB that is on its way.... :bonk:
n8rsk8r
Olathe, Kansas
reading sticker off my 65mm TB says "do not clean inside Throttle Body or adjust hard stop screw. Special coating on throttle plate and bore" So I guess you can take that for what it is worth SHOfun 93 :rolleyes:
