cfkull
I have read on some SHO sites that the upper intake can be removed in 10 minutes, maybe as long as 30 if you have never done it before. I don't believe it, unless there are some shortcuts that I am missing. The passenger side rear upper manifold support bracket is nearly impossible to get out, I must have spent and hour on it. Are there any good guides? Factory manual is less than helpful - "remove all the vacuum lines and coolant lines" then take out 12 bolts is not what I needed, and besides there is more to it than that.
The (again) reference is because I knocked the back corner loose on the rear cam cover gasket while installing it and now have a worse oil leak than the one I was trying to fix.
Problem #2. Other than the oil leak, the car will not idle now. Any suggestions as to something I might have over looked or not hooked back up? Won't start unless I press on the gas pedal.
:corn: :laugh_ti:
LMAO
