I have a code 551 with no other faults. The butterflies appear to close on start up. The car runs a little rough at idle but that may be normal with 255K on the car. I checked the solenoid and it is reading 75 ohms which is within range and it has 12 volts going to it. When i put a vacuum on the runners they open. When I start the car they close. When I replaced the PCM (eec) with a used one the fault remains. What gives with this code and what else can I check? Should I replace the IMRC even if it Ohms out as good?
