Well, as stated on the Fel-Pro box and what was included inside:
2 Intake manifold (between the intake manifold and the block)
4 Intake to upper manifold
2 Intake to lower manifold
1 idle air bypass
1 idle air bypass to intake manifold.
One idle air bypass goes between the idle air bypass and the coolant piece, the other one goes between the coolant piece and the intake manfiold. Not sure if I am describing the "coolant piece" correctly.
I'll see what happens when I put it together.
I've looked into some other gasket material at McMaster Carr.
You can buy much better gasket material than paper.
The best choice seems to be "Premium Compressed Aramid/Buna-N Gaskets".
Sheet size is 15" x 15" (longest gasket is 12.5") and 1/32" thick (paper gaskets thickness) for $9.57.
It is stated that the material has a temp range of -40 to +400F, and "resists most acids and alkalies, water, steam, oil, and detergents. Maximum pressure is 1000 psi, color is blue".
There are more exotic materials like graphite, carbon, teflon and silicone, but for a 15"x15" sheet the price is the $100 range.
I've made some templates from the paper gaskets and see how the aramid/buna-N material come out. I don't have a punch so I'll have to use one of those very sharp, small blade hobby knives.
