Instrament panel lights
HotBoxSHO
Portland, Maine
I successfully installed my new Alpine CD player today. The problem is when I was installing it, I accidentally touched some of the wires together, and my instrament panel flickered once, and then went out. I checked fuse 8 but its fine. Everything else works. Any ideas?
'93 SHO ATX. Inner airbox removed, 15% tint, Fishtank mod, Alpine head unit.
Check more fuses. I have seen more than one fuse identified incorrectly in the manual as to the systems protected by it.
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
T
ThatSHOkid
Guest
i agree with sdpatt. check them all. oh yeah and make sure u check both corners of the fuse. for soem reason i checked one side of the fuse and tyhey all worked but my windows/locks didn't work, but then my dad lectured me and said check both sides which i forgot to do and bingo it worked., found the fuse, and ****! the problem was gone.
HotBoxSHO
Portland, Maine
Sure enough, a 5 amp fuse was blown instead of the 15 amp fuse that the manual said ran the dash lights. I replaced it, and now they work. Thanks for the advice.
