92ShoOff
So I'm installing a Fidanza flywheel with a brand new insert, a brand new SPEC stage 2+ clutch kit (clutch disc and pressure plate), a 1,000 mile old SHO NUT ceramic TOB and Teflon coated bushings, and a brand new quill sleeve.
While I had the engine out of the car for 7 months I happened to get a few specs of dirt on the TOB due to an armadillo digging a hole under my car while it was parked on the side of the yard. I just the other day pulled the TOB from the clutch fork and asked Josh @ SHO NUT what he recommended I do with the TOB. He suggested for me to clean in up very well and re-apply some synthetic grease to it. I picked up some Mobil 1 synthetic bearing grease and just finished applying the grease to the fork contact area on the back side of the TOB, as well as where the original grease was on the other side of the TOB where it meets the pressure plate fingers.
I took the fork and bushing assembly and shaft out, cleaned them up, and applied silicone caliper pin grease to the fork shaft, inside and outside of the fork bushings, and the inside of the fork where the shaft slides in at.
Yesterday I installed a the new quill sleeve using Permatex sleeve retainer. After everything tried I cleaned the quill sleeve with brake parts cleaner and installed the TOB onto the sleeve with a dry fit. No grease on the inside of the TOB nor on the outside of the quill sleeve.
Does everything look good? Do I have too much bearing grease on the area of the TOB where it meets the pressure plate fingers?? I guess the only thing that's left is too clean the pressure plate fingers with some solvent (I have some acetone laying around somewhere). The flywheel has already been torqued down in both stages, as well as the pressure plate. Red Loctite was used on the flywheel and pressure plate bolts, and I will be using it as well on the bolt the secures the TOB fork to the shaft. Is there anything else that I'm missing or anything else that you all suggest????
Thanks,
Andrew
Thanks,
Andrew
