Input Shaft Front Bearing (E9DZ-7025-A)
Black91SHO
Irving, TX
Ford's discontinued the input shaft front bearing (E9DZ-7025-A) for the MTX tranny. Anyone know of an alternative? If so, where can we get one overnighted from?
Thanks so much.
Black91SHO
Irving, TX
Sorry it took so long to get back to you, shomethe$$$.
Thanks so much for the dimensions! Maybe we can find a company making bearings with those dimensions.
Black91SHO
Irving, TX
Well, dang... That's the smaller bearing. Unfortunately, it's the other bearing (the bigger one) that I need. Thanks for trying, though. Much appreciated it.
I think the bigger bearing is pretty hard to find, but I could be wrong. The threads I read about it were old threads, so maybe Timken started making them later than those posts.
shomethe$$$
Washington D.C.
That one is obsolete but Shonut should have one or see below, contact him. Bearing is ST3265-N. The cup is still available its LM48510N.
shomethe$$$
Washington D.C.
Two available online as well
http://www.ebay.com/itm/181737697814
Plenty still available here:
Ford of Englewood
Englewood, NJ 07631
RPN Parts
Erie, PA 16509
Green Sales
CINCINNATI, OH 45237
51
Gordie Boucher Ford of Menomonee Falls
Menomonee Falls, WI 53051
Bob Allen Ford
Overland Park, KS 66212
Parts International Farmers Branch Ford
Farmers Branch, TX 75234
22
Bowman Sales And Service
Bowman, ND 58623
https://www.partsvoice.com/partsearch
Black91SHO
Irving, TX
Nice. Where do you find this crap?? I scour the net and find nothing. lol
I emailed SHONut right when I started looking for the bearing. Josh replied with something like, "It's obsolete. I know of no alternative."
I'll try those other two you found. Thanks!
Black91SHO
Irving, TX
I went and checked the ones you posted. That's a different part number. I'm looking for: E9DZ-7025-A. The one you posted from eBay is: E3FZ-7025-A
When I called Ford after first searching for this bearing by part number, they said it was obsolete and their system couldn't find any in the U.S.
I tried your link to www.partsvoice.com/partsearch just now. Same thing--none found.
All of the threads I've read on this subject have said it's no longer available and you just have to get it off of a used input shaft, which is a pain. But if that's what has to be done, that's fine.
Thanks for your help!
zach44102
BIG TURBO
Georgia
Is this the bearing that Texantony is looking for to finish the HD gearset?
shomethe$$$
Washington D.C.
Your not gonna find that one, you can find the cup but not the bearing, like I stated above. Getting one off used one would be pointless because that bearing maybe jammed onto the shaft, unlike the mainshaft which slides right off (even this one seizes on the shaft). So your only other option is get the next size standard bearing which is a LM48549, both of these use a LM48510 cup and then get a bushing made. These bushing's are very close to what you need.
http://www.ebay.com/itm/bore-Bushin...aper-cutter-/291566617543?hash=item43e2b983c7
Black91SHO
Irving, TX
Thanks, man. That's an interesting solution.
So the outside dimensions are exactly the same, but the inside cup is just a little bigger?
shomethe$$$
Washington D.C.
Yes, its the exact same cup as the E9DZ-7025-A, which is 65.088mm. The inside cone (or cup if you want to call it that) for the E9DZ-7025-A has an ID of 31.95mm (the diameter of your input shaft). However, that cone is impossible to find so the next size cone is for a 34.925mm shaft. Which is the LM48549. Hope this helps.
