Input / Output Shaft Seals (Half Shaft Seals)
Marccus
California
I need to replace the half shaft seals on my '89. I have to add about 1.5 quarts a month to keep correct level. Transmission has 370,000 miles and original seals.
I've been researching the previous posts for information. One question arose.
Where is the anaerobic sealant specifically used?
If everything is rotating what is the purpose of a "sealant"?
Marccus
California
OK, I should have realized that.
Why can't RTV be used? It is used on the camshaft seals.
sho'd
Git R' Done
ontario,canada
you don't want to take the chance of some rtv getting in the trannie and blocking some passage up. you wouldn't believe how small some of the holes in the valve body plates are.
projectSHO89
SHOless In St L
He has an MTX. Hard time finding a valve body on one of those...
FWIW, I've never used any sealant and haven't had any leaks....
Steve
Marccus
California
Sounds good. I go the "no sealant" route. Besides any leak is better than the leak I have now!
Howdy_Doody
Chesterfield, MO
Actually, I had one installed at a dealer without sealant and it did leak. The seal is just below the level of transmission fluid, so it can find it's way out. That's why they specify a sealant on the outside of the seal. Be sure to check your fluid level after doing this job.
Storm-Chaser
Shit Louis
The Ford part number for the anaerobic sealer is B5A-19554-B.
I tried ordering several tubes some time ago when it became apparent that Ford was discontinuing/obsoleting everything to cut costs, and found it was no longer available. :shakehead
Anyone have a superceded (updated) part number, or recommendations based on what they're now using?
Storm-Chaser
Shit Louis
Calling Howdy_doody....
Howdy_Doody - since you hadn't noticed this post yet, was hoping to get your insight/inside knowledge on the recent change to the Moog Cargo Coils: (Moog CC break-in)
Storm-Chaser
Shit Louis
You can also try E1FZ-19562-A
