injectors/ and tuning computer
loboreno
NY
When do you really need bigger injectors? I have a 3.0 . Full 60k tune up, x2j computer, eh intake, bbb taylor 8.2 wires , high flow y pipe, 2 1/2 exhaust into 2 super 40s. Everything else motor wise is stock. I had stock injectors clean few years back. Anyone have some advise. Please??? Also with the x2j computer when should I worry about changing the tuning?
loboreno
NY
oh ya i forgot ....
Stock fuel pump ( e2001) 95 lph I think....
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Generally you wont need injectors unless you are running boost. If you find you are running lean then you would need to run a Tweecer: SHO Source
You can then run 36lb injectors: SHO Source
You would need to upgrade the fuel pump: SHO Source
yamahaSHO
E85 whore
Arkansas
You will not need injectors for your setup. Tuning, on the other hand, can improve power, drivability, and fuel economy.
loboreno
NY
with bbb
Should I keep the intake horns in or take out? Should I leave tb stock or go bigger when I get tuning done
AREA 91
PA SHO SHOP
Area 91
You need to remove the horns with big bore butterflys.
They will be a restriction.
A bigger throttle body Isn't necessary at this level.
The stock injectors are fine. No need to upgrade.
I recommend a new fuel pump, especially if it's never been changed.
A tune will help in all aspects.
Enjoy.
