Infamous Slider Pins
RTStabler51
El Loco
Burke, VA
I've looked in my Chiltons, and searched thru here, and don't see anyone saying how to get out the slider pins. Well...How do you get them out?? I believe they are my problem on my RR caliper hanging up, which it didn't do before I rear did my back brakes. Any suggestions??
jthomas68
Area 51
You know the 15mm nut you have to hold while taking off the 2 caliper bolts,thay are the ends of the slider pins.Pop off the small boot,and they SHOULD slide right out.
RTStabler51
El Loco
Burke, VA
LOL, your suppose to hold those?? Hmm I didn't have to.....tho I did turn on them for awhile after I took out the caliper....glad my dad brought home the torch........
jthomas68:
SHOMA
Springfield, MA
FYI, On my 94 ATX, I got stuck on vacation, (lovely sho's!), with metal/metal front brakes. On the front left of a 94 atx at least, one got stuck when I went to install the pads. That slide pin should be free, nothing holds it in but the bolt that you took out to install the brakes...... I had a guy at Midas heat it up with a torch... and it came out, but I lost the rubbeb boot, but greased the heck out of the pin once freed, and its been good ever since! Good Luck!
