Ignition Problem? Car wont Start!
SHOWYA
TurboSHO Member
Houston, TX
I had to change the plug cylinder seals and replace water pump. And abviously coolant got to the CPS sensor. I have dried the CPS sensor. I had to replce the Fuel Relay ... no pressure on fuel rail. Presure is restored and installed a 190lph pump ... car will still not start. Checked for spark on wires ... wires are good. Does the coolant actually damage the CPS sensor? I checked the codes and ill get ' PIP circuit fault' once in a while after many times of trying to get the car started. Car will try to start but now all i get is just cranking. PLEASE HELP!
stevetatro
Cincinnati, Ohio
The PIP circuit fault does indicate a bad crank position sensor.
I don't know what year you have but you should either have a code "14" ('89-'91) or "211" ('92-'95).
If you do a "Search" on this forum you'll find this is a common problem.
Good luck.
David Carpenter
