PODinUT
HI out there,
I have been working on my SHO for 4 weeks, I stalled in the middle of the street while it was running fine. Wouldn't restart, got no spark. Seeing as the problem happened in the past I changed the crank shaft sensor, no spark, so I went on to change the cam shaft sensor, had the DIS checked (good), checked all grounds, fuses, changed the D4U1 computer , changed all spark plugs, I have fuel pressure, cylindars are not dry, and my scanner tool still says no communication from the car, so no codes! I also have no check engine light when I attempt to start her. Can you give me some idea as to what I can check next? I would love to find some wiring diagrams for this POS! 1994 SHO 3.2L Auto Trans
