When I bought my 95 SHO three years ago, I notice the key can be pulled out of the ignition cylinder, while the vehicle is running. The cylinder also seems a little loose. Last weekend when i tried to start my vehicle, nothing happened. My head lights worked fine, and the electric accessories came on without any problems. When I turned the cylinder back and forth, there was no click, but I could hear the fuel pump. After trying to start the car by turning the cylinder back and fourth, it finally turned over. For the next few days I had no starting issues, then on the third day, the same thing happened again. I spent two or three minutes turning the key back and forth, until it started. I’m not sure how much time I have left, before the vehicle won’t start at all. Would this be an Ignition switch? I had the battery, alternator and starter checked last spring, and all were in good condition.
Thanks in advance!
Thanks in advance!
