if i change my 1995 ford taurus sho 3.0 l dohc to a 3.2 l engine do i have to change the computer
mevik11
zak
east of Hartford
The 3.2 L injectors flow a tad more than the 3.0 which helps compensate for the larger displacement
no, the computer recognizes the slight difference in displacement because the mafs reads more air going into the engine, and the computer knows what to do with that information so all is well. btdt.
What happens if the compression ratio changes? Does the computer need to be updated to accommodate? The CR for both 3.0/3.2 is about 9.8, right?
Off Road SHO
Moderator
Ah what? Yes you do. The engines are not easily swapped, there are a lot of differences, the injectors being one of them, the engine wiring harness being another. There are differnces between mounting points, oil pans, front timing covers, alternators etc., etc.
What are you really wanting to do and why?
Tom
mevik11
3.0 timing belt broke bent valves saw a3.2 for sale wanted to know if I could drop it in
mevik11
3.0 broke timing belt bent valves saw a 3.2 for sale wanted to know if I could drop it in
unless there is a lot of carbon on the piston tops...
lingyuair
