It will jump to about 1500 rpm then drop down to below 1000 and up again then when I drive it will stop it might happen two or three times a weekHow many RPM?
pax, smn
Look at the Idle Air Control (IAC) valve first. May not be it, but it is a good place to start.
Next would be the Throttle Position Sensor (TPS).
It sounds more like the TPS to me than the IAC. Both are easy fixes, though, so it almost does not matter which you start with.
pax, smn
