Racin Repair
I searched the idle reset procedure and amd going to try that this weekend..
Heres the problem Im having;
Start vehicle idles normal.. Touch the trottle and it stays at 2-2500rpm and does not drop back down.
I just installed a ported intake, larger secondary throttle blades and a bored tb. No vacuum leaks as if I unplugged the IAC ( which is not on backwards! lol! ) it immediatly dies..
The larger TB blade did not have a hole drilled in the plate and I thought that may be the issue as Ive had that problem on v-8's ive built so I drilled a small hole to see if it helped air flow to get the IAC to drop down but no change..
Does everyone think the idle reset it the problem with this?
