GIGS PERFORMANCE TB Update
kryptto
South East, Florida
So I have a thread or 2, one in what did you do to your sho. Garbage, just garbage.... don't buy. EBay seller.
From Brad:
"Are you able to use the stock motor and electronics on the new throttle body...I feel like that's probably where the issue is...Tuning for throttle body size is one thing but the motor and electronics is something else that I'm not sure I can tune for. You have slopes and ratios for the motor movements that I'm not even sure we could get the proper data that needs plugged into the tune
I have an upgraded throttle body on my mustang that I got from VMP. They only use native OEM throttle motor. That stuff can make it near impossible to tune properly. The size of the throttle requires tuning to correct the airflow model. The ECU uses calculations to convert throttle opening and the area of throttle opening to a desired air load
Would be interesting to see if the issue is gone with the stock TB which I expect would be the case."
Science experiment is over for me... @Jordan_R
chrisjobe
Williamsburg, VA
The s197 v6 bbk tb is a direct fit on these cars and is plug and play. No real performance gain but it has a better location to pull a boost reference which is what I use
kryptto
South East, Florida
Thanks, yeah I heard about that TB. Maybe I will see. Wasted my cash on this crapola.
kryptto
South East, Florida
On a plane - have the BBK model number for our TB? Thanks
chrisjobe
Williamsburg, VA
A578275978e2b1e29e24876d65554667
E78200827d89397ae96cb4dd0c42071f
81f2d59d50e2210d0e0d9c8d138e7ce8
Before I put mine on I went ahead and had a boost reference port installed. Get a good machine shop as they are prone to cracking if you just hambone the piece in there. The v6 tb is flipped over so the port is on what would be the “bottom” of the tb in normal orientation.
