Ecoboost_xsport
What goes through my mind when I look at that View attachment 12866
Off topic: I feel you on this. It's currently how I feel with the actual factory PWM fuel systems. I've got the XDI HPFP-60, about to install their 50% injectors and also the in-tank DW300c. On an E85 tune, it's still not enough of an in-tank fuel pump to deliver what it needs, so I have been struggling with trying to design a fuel system that will work well.
Sure I could go old-school and just change to a traditional fuel pressure regulated return style system, but it just doesn't seem right, not to mention, I'm not sure how the PCM would play with a setup like that. I'm going to go the surge tank route, but since the factory uses a return-less PWM method for fuel delivery, I'd really like to retain that capability and have been mapping out plumbing and wiring (at least trying) for a Radium Engineering PWM surge tank setup with dual Walbro 450s using Solid State Relays as I'm not sure the factory fuel pump control module can drive those dual walbros. I'm a little out of my depth and am doing all the research I can on fuel systems to see if this is feasible. I just ran across a guy online yesterday who has a GTR with this exact setup and, although it is a different platform, may be able point me in the right direction if I can pick his brain a bit.
So yeah...right now, I feel like that meme when I get explained some of this fuel system stuff, lol.
