Venom SHO s7
I recently upgraded my subs/amp from a pair of 12inch MTX thunder4000 and a Prestige amp to a pair of 12inch 2003 Kicker Solobaric L7s and a HiFonics Brutus bx1500d amp.
The subs handle 750rms each and the amp can put out 1500watts RMS into 1ohm.
Im going to do the install myself since im descent with car audio stuff.
so my question is...
How do i go about wiring my subs so that they will give a 1ohm load so i can get the most out of my amp?
The subs are the dual 4ohm version and are in a sealed box with each box having its own sealed chamber. So its like having 2 boxes glued to eachother.
All the other subs ive had have been single voice coils so now that im dealing with DVC subs im kinda unclear on how exactly it is that the Ohm stuff works.
Can someone break down the principles of how to go about wiring these subs to get certain ohm loads? and the advantages of wiring them parallel or inseries?
Also, ive never noticed any problems with my sound getting static because of having the RCAs and power wire on the same side of the car, but ive heard its beter to have them away from eachother.
Is this really a concern or not really if you have the 'shielded' RCA cables?
thanks for the help.
