Dirk37
Mr. Resourceful
89 SHO Taurus Turbocharging Guide
Here's a fairly detailed writeup on how I turbod my 89. This is not easy or cheap, but its a ton of fun if you're willing to put the effort in. Some disclaimers before you read this:
-I don't really know what I'm doing
-This was done on an 89 mtx, I don't know anything about atx cars or 2nd gens
-If you do burnouts your transmission will explode
-Your gas mileage will decrease significantly
-3rd gear will probably explode at some point
-You will have a ton of fun and probably understeer to your death
-I recommend giving Toolmans thread a read as well
-And yes, I know my car is a piece of crap lol
A little info on my car before we get started. Like all great projects, I bought this car my junior year of high school (2013) for $600 - I now have $8500 into it. When I got it, it was in pretty rough shape and needed a clutch. I replaced that in my high school auto shop and then started using the car as my daily driver. It needed a full 60k and lots of other things fixed, and I spent about $2500 just getting it to good running condition. Before you start on your turbo journey, make sure all of the routine maintenance is taken care of - especially rod bearings and a full 60k. After I had it running I decided I wanted to go faster. I got BBBs, a y pipe, and a tuner which made a big improvement, but I still wanted more. I saw some turbo sho's on the forum and decided that's what I wanted to do. I began collecting parts, and continued collecting them for 2 years until finally in the summer of 2015, I got around to actually putting the turbo on. What a blast! It was so much fun and my only regret wasn't doing it sooner. It took me a few months to work all the bugs out. I had a handful of mechanical issues detailed below, as well as some tuning frustrations caused by bugs/missing features in the tuning software (which I have provided workarounds for below), but after getting those resolved the car runs great. I am currently daily driving it and get about 16mpg with mixed driving, <14 mpg street only, and 23 mpg highway only. I'm running about 7-8 psi of boost and estimated hp is a little under 300 at the wheels. I still have the stock clutch which slips at any more than 8 psi. Once I get a new clutch I'm going to turn the boost up to 13 psi which according too Toolman should make around 400 at the wheels. Engine is also completely stock. Even with Contintal DW max performance summer tires, I can't keep traction in first or the top of second in the dry. Don't even try to boost in the wet if you want to live. I have aluminum subframe bushings, poly bushings everywhere else, and subframe connectors which all helped with traction, but I still have issues. There's also a bit of torque steer, but with good suspension components its manageable.
Parts List:
Warning: Do not buy cheap parts, they will come back later and ruin your day. For example, I had a crappy intercooler on the car and it wouldn't boost past 3 psi aboue 3500 rpm because it was so restrictive. Took me almost a month to figure out. Also had a cheap silicone coupler that ripped in a spot I couldn't see. Car kept getting slower for weeks until I pulled it apart and found the rip. Spending a little extra money will save you tons of time and headache.
Turbo stuff - $1310:
Turbo (Toyota Ct26) - $300
Turbo Flanges for exhaust - input and output - $80
Oil feed line and oil return line - $50
Oil return fitting in pan - $10
Fittings for oil feed - $30
Oil fittings for turbo -$30
Turbo piping - $120
Intercooler - $100
Blowoff Valve - $100
Wastegate (Tial 38mm) - $200
Wastegate ******(s) - $20
Exhaust piping - $100
O2 bungs - $30
Exhaust heat wrap - $25
Hallman boost controller -$115
Engine Management - $1695:
MAF (90mm lightning maf in turbo piping) - $100
MAF ****** - $30
MAF Connector $5
Injectors (Siemens Deka 60lb) - $300
Modded fuel rails - $100
FPR (Mallory FPR from shosource) -$300
Fuel pump (Walbro 255lph from shosource) $100
Tuner (Quarterhorse, Tweecer, or Megasquirt) - $600
Wideband gauge (Innovate MTX-L) - $160
Other - $55:
Boost gauge - $20
Check valves for vacuum system - $15
Autolite 3923 or NGK BKR6E spark plugs (1 heat range colder than stock) - $20
Premium gas
Approx total cost: $3060
Exhaust Piping:
The first part to build is the exhaust system. The whole thing is made out of 2.5 inch steel pipe.
First part I made was the upipe to the turbo. I built a y pipe thing that puts the turbo right above the transmission. For the most part this is out of the way of everything critical. I did have to cut the thermostat housing shorter and get a different hose though. I got the collectors from summit I think. Making the pipe is kind of a pita. First I got all the bends I needed from an exhaust shop. Then I bolted the collectors to the headers and started building it from there. It took a few days of test fitting, cutting and welding. This whole thing was built with a little mig welder and holds up fine, so you don't really need any special tools. I would recommend a chopsaw with a metal blade though as it makes cutting the pipe way easier than an angle grinder. As you're building the pipe keep test fitting the turbo to make sure it will fit on the end of the pipe. You'll have to get rid of cruise control and a whole bunch of other stuff on that side of the engine to make it fit right. I welded the wastegate ****** into the y pipe right after the rear collector and it just dumps out under the car. I might hook it up to the rest of the exhaust some day but it works and surprises people haha.
The reason I chose an external wastegate was because the turbos internal wastgate was super small. Also I had to reclock the turbo housings to work in that location, so the internal wastegate actuator no longer worked. I just welded the internal gate shut on the turbo so I wouldn't have any issues. The wastegate is something to not cheap out on. Cheap ones will rust shut and allah u akbar your engine when the turbo over boosts. I originally had a cheap wastegate I got on craigslist and it was missing the wastegate seat, so the turbo didn't spool till 5k. I spent a few hundred on a nice tial one and have been happy ever since. I would recommend getting a super low pressure spring (4 psi) for the wastegate and then using a boost controller. Hands down best one is the Hallman boost controller.
The downpipe is kind of a piece of crap. I couldn't figure out a good way to do it with solid pipe, so I cheated and used a flex pipe covered in heat wrap. It seems to work relatively well. I was having issues with the wiring melting on the heat wrap so I have a cardboard spacer between the pipe and the wiring. Not recommended though. To make the downpipe fit the speedo sensor needs to be moved or else it will hit it. The speedo cable system is in three parts, two cables and the speedo sensor. I switched the lower cable and the sensor so that the sensor connected to the upper cable instead of the transmission, and the downpipe fits just fine after that. The downpipe then just connects to the stock exhaust. Now this severely restricts the exhaust flow of the car. I have a cutout right after the downpipe though so I can flip that open and gain like 20 horsepower. I'd recommend a full catback though.
Parts List:
Turbo piping - $120
Intercooler - $100
O2 bungs - $30
MAF ****** - $30
MAF Connector $5
Other - $55:
Boost gauge - $20
Premium gas
Exhaust Piping:
