How to repair your windshield wiper governor module
itwonder
VA
It's called the windshield wiper "interval governor" in the FSM, but even Ford couldn't agree on the name because it is labeled "wiper control module" inside of the unit. Either way, it can be responsible if your wipers don't work or work sometimes, but not other times. On my car, the wipers would not work unless the switch was left on for 10 minutes or so, and then they would magically start.
This guide explains how to remove the wiper governor, what to look for inside of it, and how to repair it.
1. The governor module is located under the dash, more or less above the gas pedal. It is mounted on a plastic bracket along with with other relay modules. Remove the two screws from the bracket (one removed already in the photo). Then lower the bracket and twist it so you can access the governor module.
IMG 0129 Small
2. Free the module from the bracket by pushing in the tabs inside the red circles and sliding the module off the tangs. Then disconnect the wiring connector.
IMG 0138A Small
3. Pry the two latches on one side of the module off of their retainer tabs. The cover can then be hinged upward and removed.
IMG 0124 Small
4. Remove the circuit board from the case. Pry out the two plastic tabs (one on each side) that retain it just enough so the board can be lifted past the tab. You can do this by prying from outside of the case with a thin blade screwdriver. Take care not to damage the circuit board.
IMG 0127A Small
IMG 0123A Small
5. Inspect the back of the circuit board with a magnifying glass and a bright light. On this one, a cracked solder joint is fairly easy to see. The crack may be hairline.
IMG 0117A Small
6. Re-solder the broken joint; a 15 to 30 watt soldering iron will do a good job.
IMG 0121 Small
7. Snap the board back into the case. Attach the cover, taking note that the end of the cover with the large tab goes over the connector. Re-install the module in the car and test operation.
IMG 0126 Small
IMG 0125 Small
IMG 0137 Small
This repair will save you about $70 for a new wiper governor module, or a trip to the junkyard to get one that might be cracked too!
Of course, the multifunction switch and wiper motor must also be evaluated when isolating a problem with the wiper system. Other forum posts cover how to clean a malfunctioning multi-function switch and replace the wiper motor.
TwistedMunky
yakima,washington
Just wondering mine wont park, only have two modes on and off. They stay were ever you turn them off at. Would this be the module or in the switch?
Geek SHO
SHO Addict
Rohnert Park, CA
Reviving an ancient topic here, but I've had this EXACT problem for several years and only now found this thread. The wipers work fine with the multifunction switch, but refuse to park. The closest I've gotten is to switch it to intermittent, then turn it off during a pause. I knew it was the wiper control module (or governor or whatever, getting the right name was part of the problem) but could not identify which module it was under the dash. I will take another look, but I have a feeling it is different for '89, like so many other components.
tommyturbo
California
I had an issue where the wipers turned on by them selves for three sweeps, like as they do when you push the washer button. Tried cleaning the corrosion on mine, found no bad solder joints, but that didn't resolve my issue, so I just replaced the module...problem solved. Was actually surprised you could still get the module.
Nuke
SHO Wagon
Near Reno
Ohmigawd. This has to be my issue. There is a little box under my dash that squeals when I try to park my wipers. I already put a brand new wiper motor, and a NOS control stalk in it, and it still doesn't work. Hopefully this will fix it. Otherwise I need a new one for an 87 Sable.
Thanks!
emiaj zerolf
The wipers of my 1997 Ford Ranger don't work when I want . This post could be the answer to my problems. Can I see the pics, please?
itwonder
VA
hello I cant see the Pics. How can I go about doing so?
The blame belongs to the shakedown artists at photobucket who lured 1,000's of forum posters from across the Internet, including me, to use their "free" service to host photos that are linked to forums like this one. Now, they've started charging big bucks; folks cant' pay, and they cutoff access to the photos. Nice bunch.
The good news is I've edited the original post, replacing the photobucket links with the original photos that I've uploaded directly to this forum site, where hopefully they will stay put :) So you should be able to see everything now.
randy wilson
texas
Thanks to itwonder and his post I repaired my 1992 Ford F150 wiper control module. Mine was behind the glovebox and it did have issues. I re-soldered some joints and traces. Now I have voltage at the wiper motor. Wiper motor was still bad, replaced and now all is good.
huglasdon
Usa
Has the location changed for 2013. Not seeing it in the location description. Their wanting 1300 to replace and program.
Carlos J
California
This tutorial was great I was able to repair my module in no time and save me atrip to pik n pull 50mls away from my house that was the closes vehicle inventory to my car 89.
Thank you for all your help.
Juan C Jauregui
raymo23
